1047987
just wanna add some opinions.
2L is pretty much never needed, but it can come in handy if you use the jeep as a "workhorse" and are moving heavy loads on pavement, or pulling brush, or something and you don't want that 4-wheel-bind from 4L on pavement.
with my twin stick, I play with it alot. my garage entrance is tight and angles, so instead of slipping the clutch, I drop it in 2L first, dump the clutch with no gas pedal and let it crawl up the driveway. when I crank the wheel hard to turn in, it is idling around 400 rpms just chugging in, kinda fun, but I'm kinda weird.
also, 2L is fun in drive throughs. doing 2,000 rpms at 5.5 mph gets some funny looks.
(kinda wish I had one of those super-low crawl ratios so it was more obvious
also, before my twin stick, 2L was accessable by "cheating". using 4L, but unlocking both hubs, you only have rear drive, hence 2L
One concern about 2L, and a reason I think it is usually unavailable, is you can put tremendous power to just that rear axle, and I think breakage is very possible in high-traction and hi-load situations.
also, if you have an open differential(i.e. stock), unlocking just one hub also can disable the front axle(thats how YJ's work, they only disconnect one axle shaft) so if you are stuck sometime, and the front is not pulling, check -both- hubs to see if they are locked.
that got me once when I was very young. and again when I was much older.
and...I tend to leave my hubs engaged all the time now. with the twin stick I don't need to use the hubs anymore, and this way the front and rear axles will wear out at the same time.
You can save some mpg(not much, but you can experiment for yourself and see) by using the hubs. if you do use the disconnects, and don't off-road regularly, make sure to engage the hubs once in a while. I think a couple times a year would do it, but it needs that to lube the front end.
also, if you -do- offroad regularly, check the diff fluids, and both gearboxes(transmission and xfer) to make sure no water is in them and that they are full on a regular basis. best shortly after done off-roading.
I've never regretting inspecting my vehicle, If I don't find anything wrong, so much the better.
If I do find something wrong, its better than finding it buried in two feet of mud.
-keith[addsig]
