Soa lift driveshaft length??
biggwheels
1993 yj renegade , I did a spring over , did it all right by adjusting my diff angles just curious what length drive shaft I will need for the rear or what different vehicle will have a driveshaft that would be the proper length ?
All help is appreciated thank you
How to measure a drive shaft
I've heard of the XJ guys takeing a front DS from a other XJ because it has a double cv joint and bring it to a drive line shop and have it made the lenght they need for the rear.
Though I'm not sure if the u-joint size will be what yours is.
you need to measure and have a shop make you a shaft that fits. you could just cut down a XJ shaft, but it would still need to be balanced, there is no set length for a shaft, there are so many variation in drivetrain lengths that there it would be nearly impossible to have someone say you need a XX long shaft.
measure from center of u-joint cap to center of u-joint cap at ride height
measure from center of u-joint cap to center of u-joint cap at full compresion
measure from center of u-joint cap to center of u-joint cap at full droop
you will also need to know what joints you have and where the slip shaft is going to be located, in the out put of the tcase or in the shaft, do you want a CV shaft or a traditional u joint shaft.
take all this and head down to the drive shaft shop and they make you one.
of check out tom woods web site, great info on how to fit and measure for a shaft
