Ok after one of my brake lines rotted away I decided to replace them all with stainless lines. The jeep sat for about 3 weeks (long story) until I finished everything. I bled the system very well, went through the whole sequence twice starting at the rear pass drum and working towards the drivers front caliper. No air bubbles at all, ran a ton of fresh fluid through. The pedal is still soft and has a lot of travel. The strength of the brakes is about the same as before, with 35 in tires, it sucks...lol. I don't remember if the pedal was much better.before. the jeep is a 97 with abs, the abs fuses are pulled. When I did that, it didn't affect anything. In the spring I plan to fix the abs and swap in an 8.8 rear. But is a sort of softish pedal normal? What else can I do to help this. I am going to make sure that the rear shoes are adjusted tonight.
