I just bought a 92 Wrangler with a 350 its got a 700 R4 Transmission it runs great but the speedometer does not work. Anyone know how to fix this? Can I buy a replacement cable for it?
Check first if the YJ cable is compatible with the 700r4 trans.. The cable ends are square and it has to slip in the speedo shaft on both ends. Check if the threaded ring would fit the housing on the trans.. If it does, the cable is possibly broken.
