danimal1975
I have a 92 Jeep Wrangler that has been swapped from a 4cyl to a 6cyl, out of a cherokee. It has the bigger transmission as well. I so far have replaced the VSS, instrument cluster, and adjusted the speedo gear to every different setting available on the T-case with still no luck on getting the speedometer working. Every chart I look at says it should have a cable but it doesn't. for the setup it says I should have a short shaft 33 tooth gear set at 2628. I opened it and I have a 33 tooth long shaft gear. It does not look like the short shaft gear will be long enough but that is what the app. says Im supposed to use. Can anyone please direct me to the next step???? Im lost!
