If you go to a junkyard, look for an older model GMC or Chevrolet pickup truck that has a round cast aluminum column case. There are two versions, Auto or manual. The only difference is the PRNDL indicator on top.. The lenght of the lower shaft also varies however, you can swap the one off your old column to the replacement one if needed.
