Here are some thoughts I've been having. I bet I could find an isuzu rear end at pick n pull, as well as a wagoneer narrow trac front end. They just about have the same width, would have disc brakes all around, I would get the stronger isuzu rear housing, and would not have the pinion problems of the scout II front axle. As for the springs, the jeep will be rather heavy with 35" tires, d44's, tire/gas can carrier, possible winch, possible utility trailer, etc., and will have an abundance of torque capable of destroying stock yj springs in a soa setup. Traction bars would defeat the purpose of soa by limiting wheel travel unless I get that expensive one from sam's offroad, which is expensive. What would happen if I built my own military wrapped stock yj springs using main leafs from an extra set of yj springs, and threw in an extra leaf lower down? Would this bring spring wrap and spring weakness back into par with an re sua setup? or would it also reduce the flex of the yj springs so that they don't flex much better than lift springs? Basically I see my jeep as lacking in tire size and suspension articulation, not lift height...so the less lift height the better as it will make me less top-heavy. Also, the jeep is not so much a rock crawler as it is a general-purpose trail rig...just food for thought.
