K, so the bad news is that i need a new carb; the good news is that im replacing the carter! I had a carter on my old engine before i swapped it out after my oil pump dried up and the motor seized after a transmission rebuild. (Thanks AAMCO) ANYWAY, that carb ran great. I swapped in a turn-key 258 with another carter, and now it has gone to shit. BBD should stand for "Buy Better, Dude" :roll: I tried swapping the messed up carb with the old one, and now its running worse. TIME FOR A NEW ONE! WAHOO! now the ultimate and famous question: WEBER or MOTORCRAFT?
Here are the MUSTS:
The intake must stay OEM. all adapters are fair game
Must Not Hinder my already shitty emissions.
UNDER $350
Now, with that said, i have done some research and it apparently seems that most people like their motorcraft 2150's ( 1.08 ) I have never seen them in action, but i believe what i hear. My neighbor had the WEBER on his YJ, and it seemed awesome. I am looking for arguments for either or; or atleast a direction as to where i can find PROS and CONS to the decision. Also, i know the weber has its own independent filter and does away with that unsightly air cleaner; does the motorcraft use the stock air cleaner or does it also get its own?
Sorry for the long post, but this is possibly the most important mod that i am making at the moment and i dont want to have to regret it. Thank you all for your time.
Rich
Here are the MUSTS:
UNDER $350
Rich
