RE: Re: RE: Yep
Ok I had to get involved. This is what I do for a living.
The life of the oil has to do with the type of engine, driving conditions, and enviornment.
I drive a Taurus for a work car and have sent my used oil back to Exxon for lab analysis. My driving and my engine can usually go right up to 4300 to 4600 miles before the oil becomes saturated with combustion byproducts, once that happens the oil soaks up all it can and suspends it until your next drain. Push it a little too far and you make deposits. The ad pack was still about 40% there at those miles.
If the oil looks dirty, that is a good thing. It is holding the particles in suspension.
No one can say for sure how long their engine will go without oil analysis and not just one but ususally a series of 3 or 4 per year to get a good baseline going.
I use conventional motor oil which is all built to the lowest minumum specs in the little donut on the bottle.
Synthetics are good, esp in cold starts and extreme hot, Synthetic blends are mostly a rip-off, they only have to have about 10% synthetic base stock to be called that.
High mileage oils have a seal swell additive to prevent and stop minor leaks.
