cewtwo
There are times when you need more than 4 low to get where you need to go.
I am thinking of buying and installing a Terra Low 4:1 system.
An Atlas transfer case would be ideal but it is very expensive. A terra low is much more affordable but you need to be a good wrench turner.
Recently, a friend purchased one and found out to his chagrin that the bolt patterns did not line up. He called terra low and found out that 25 units were bad but they had recovered them all. He informed them that they had not as his was not a good unit. They will exchange it, but they want the "bad" unit returned first. All shipping is to be done at my friend's cost.
So, I need some opinions.
1. What do you guys know about Terra Low?
2. How hard is it to install? (Keep in mind that I just recently installed a SYE unit to my transfer case).
3. Do they have a good reputation? Are the customer relations problems just a recent thing?
4. Is it worth the investment?
5. Is the Mighty YJ built up enough to accept the extra torque that the Terra Low will throw out?
(The only part of the drive train that is stock is the front drive shaft. - Front axle is a super 30 the back is a Ford 8.8 (beefed up) and a custom back drive shaft with SYE. There are 411 gears in the differential of the front and the 8.8 has a 410).
6. Is the 4:1 really going to slow us down to where we will notice it?
A good example of a recent trail was upper Spring Creek. After the rock garden there are still large rock fields that can be difficult to negotiate. Sometimes you have to torque so slowly that the engine seems to be about to die. Is a terra low the answer?
