TH400 and Dana 20
redrooster
For sale: Jeep model TH400 automatic mated via an unknown brand adapter to a Dana 20.
The transmission has less than 100 hours on the rebuild. It has a B&M shift kit installed for better performance. This will fit Jeep 6 and 8 cylinder motors.
The transfer case includes a twin stick shifter for easier shifting over the factory design. It allows for using 2WD low in the rear wheels. It will not drive the front axle only like a Dana 300 without additional modification.
I will also throw in the rear driveshaft which is set up for a CJ7. It has a CV-Cardan joint at the top and a 1310/1350 conversion joint on the bottom. The driveshaft has seen some trail use but is still in decent shape.
Both are located in Huntsville, AL and are currently in the Jeep. They will be removed in Mid April. I can provide pics once they are removed.
$500 for the whole setup.
RE: Re: JEEP FOR SALE
Red. . . still got 'em? I'M VERY INTERESTED! pm ME
