throttle bodys
what parts do i need to change to run the newer style TB? are they parts i can find in a junkyard to bolt a 91 or newer tb on my 89? or do i have 2 buy the kit? is the newer tb better then just boring out my old one?
sorry for all the questions bounty hunter, still trying to learn about jeeps, i know alot but no where near as much as some people on this forum
You would need the kit to convert to the newer style TB, no junkyard parts out there.
I would contact Hesco or check out Hesco's forum to see if your stock TB can be bored out to 62mm. If it can be, it probably would be better to have it bored than to swap to the newer style TB.
You want more power? Just swap in HO injectors (you'll be able to watch the gas gauge go down though!) With some adjustments you can do the HO intake as well (up til '95) with the whole injector set. You'll have to deal with the EGR pipe, dremeling the manifolds to fit and not suck air by the gasket and some home made washers for the studs (offset) Then the TPS needs to be hooked up. Haven't done it myself. This is from memory.
