probably will loose milage depending on where you drive. if you drive a lot on the highway, a 30" tire compared to a 29" tire does not offer enough rolling resistance to lower milage, but the slight increase in tire diameter, will slightly lower RPM's and maintain overdrive, hence slightly less fuel consumption.
