C Cminer22 New member Aug 13, 2012 #1 the other day i noticed a ticking sound. i have a 2002 wrangler. but i have also heard this common. any help? thank you
Utah_jeepster Super Moderator Aug 14, 2012 #2 Give us some details first, motor size, last oil change, does this ticking sound near the exhaust, top end lower?
JPNinPA Well-known member Aug 14, 2012 #3 Is it all the time or only in the first few min after starting? Stuck lifter,valve, loose rocker arm,exhaust leak or just the wrong oil filter. Yes oil filter should have a good check valve that does not allow the Oil to drain back into the pan. Unlikely this
