Been troubleshooting an intermittant miss at idle - '99 Cherokee 4.0 Auto 4X4. My OBD II scanner shows that the TPS is sending a signal of 15% throttle opening at idle (even though I'm not pressing on the throttle). Signal voltage form the TPS with the ignition off is 0.78 votls (within the 0.26-0.95 volt range. Shouldn't the TPS show 0% throttle if you're not pressing in the throttle?
Anybody else show more than 0% at idle?
Thanks!
Thanks!
