The rear pinion angle should be 1 to 2 degrees below center line of the driveshaft..This is because when you accelerate the pinion will then be in line with the driveshaft, if you don't have it pointing slightly lower the pinion will be trying to pull the driveshaft out and that can cause binding and or vibration on acceleration.
