Transfercase Identification
RedWrang
How can I tell which transcase I have. And front and rear diff also. I have an 87YJ 6cyl with auto transmission. What do I look for. Thanks[addsig]
1041958
transfer case is a Chrysler 999,i believe the only auto for '87-95 YJ's
front axle is a Dana 30
rear axle is a Dana 35
transfer case is either a NP-207 or a NP-231
NP-207
NP-231
hope this helps
1041970
your transmission is chrysler
the transfer cases are New Process which became New Venture
sorry about my mistake
1041979
NP-231 t-case with d30 front and either d35 rear or d44. Probably the d35.[addsig]
1041982
YJ's have a NP/NV231 t-case, a reverse rotation Dana 30 in the front, and a standard Dana 35 in the back.
Your transmission is a Torque Flight 999.
1041986
Ok folks thanks for the help. Now the question is are these parts ok or should they be upgraded. Mostly road driving , occasionally offroad. [addsig]
1041989
The D35 is the weak link. The transmission and t-case are very strong and have been used in a few v8 applications from the factory. I wouldn't worry about the front axle unless you're going over 35"s with the tires.
As for replacing the D35, it depends on what your future plans are, with what's listed in your sig you should be fine, however if you're not careful with the gas you might break stuff.[addsig]
