Help! I have a 97' Jeep TJ that I purchased in CO. There is trail scars from the previous owner. Since owning the jeep, I have had to replace two pinion yokes (1 due to axle wrap caused by two broken lower control arms) rear lower control arms, header, cat. I now I have a transmission that I am  unable to use reverse and 5th gear. For starters, when I put the t case in neutal and transmission in reverse gear while engine running, I get a rhythmic clunking sound and I can feel it in my stick shift. When running at hwy speeds, I get the same sound/feel from 5th gear. What is going on? The reverse has been out now for 2.5 years and the 5th gear for about 10 mos. Do I need to just replace my whole transmission or is there something I can do to fix the internals. I don't have alot of money and I'm looking to do this in the most affordable way. Also, would anyone know of any junk yards in MN where I can find other wranglers? I would like to upgrade my axles from Dana 35's to Dana 60's, also the most affordable way. Thank you.
