I'm planning on doing a motor swap and also wanted to switch transmissions. I was wandering if I should go with a 700R4 or a TH350? Would I run into length problems with the 700? Any help would be greatly appreciated. Thanks Evan
im about to do the same swap, im using a TH350 4WD transmission, the advantage of the 700R4 is that its 4 speed/overdrive better on the highway, but it is longer, although both transmission's will require a custom drive shaft[addsig]
