I have a 2000 TJ Sahara 4.0 automatic and notice that there seems to be alot of pressure in drive with brakes on. If I put the transmission in neutral you can feel the back end of the jeep rock upward as pressure is released. I'm pretty sure it idles at correct rpm (around 600-800). Is this normal? I'm pretty new to TJ's so I have nothing to compare with. Thanks.
