Transmition Slipping?
SailorDave
So some times when i start from a standstill, it feels like the transmission is slipping (that is the best description that I can think of) Then it will grab after a very short period of time. What the hell is wrong with my car?
Auto or manual? And what sort of/year vehicle? I don't know too much about transmission, except that it is very, very, very hard to kill the automatic (AX-14?) transmission that comes with the newer I-6 in the XJ...
Mine was shifting wicked rough, and for whatever reason, did not want to hold in park... A trans flush made it happy again. Don't know how much that affected anything, like I said, transmissions are not my strong point...
sorry, i forgot to include all that. I have a 94 Grand Cherokee ZJ limited with the 4.0 and its an automatice, it has the select track 4 weel
The problem is that your jeep has heard you refer to it as a car one too many times and has decided to take a dump on you. :roll:
Have you changed the transmission fluid and filter? I'd start there. Also check into a power flush at a oilchange shop where they do it all through the filler tube. This could dislodge any clutch band material that commonly blocks passages in the transmission.
RE: Re: Transmition Slipping?
Fluid level and or transmission filter are the most common reasons for that. Mine leaks about a pint about every month and when I dont check it a while like I know I should I will the same thing you just described.
Checked the fluid level? What color is the fluid? Smell burnt at all?
Sounds pressure related. Have you done a filter change yet?
