coastalcowboy
Need some advice. 83 cj 258 died while driving turns over no spsrk. Repalced ignition and pick up coil as well as ignition module. tested coil. neg side with key off have light. No flashing ligth when cranking. Have checked wiring from coil back,no breaks. checked #1 cycl. piston is up when rotor at #1 position. any ideas. could the ecm be bad. does it effect spark.
