mattyp25_uk
Hi from the other side of the pond.
Got myself a nice 96 Cherokee 4.0 Ltd, but also have a couple of problems too - can you help?
1. Rear Axle leaking - I've removed the filler plug, cleaned it all up and used a sealant on it before refitting but it still leaks - anywhere else I can check?
2. Sometimes after a run, I get water runoff from a pipe in the engine bay - its on the right hand side of the engine bay (as you look from the front) near the bottom. I thought it was the AC condensation run off - but I still get water even when the AC unit isn't on - is that right?
3. I don't appear to have a full time 4 wheel drive or 2 wheel drive light on the dash - only the part-time light - is that right? how do you get to the bulbs?
4. Clock resets itself to 1am every time you turn the lights on - why?
Thanks for all your help!
Matt
Matt
