i read somewhere mybe even on here that if you take one of those hand help torchs that if you run it with the gas on (flame out) over your lines that you could find leaks any one know if this works?[addsig]
Get a small and cheap LP bottle like what plumbers use to sweat fittings, the run it around vacuum lines and the intake manifold with the gas on and flame off. The engine will idle up when you're near a vacuum leak.[addsig]
