1065242
Nope. I'd sell you my trail spare, but I loaned it to a friend.
You can remove the vacuum motor from the front axle, slide the collar over the axle shafts, then replace the vacuum motor. Leave the vacuum lines off and it's okay to run on the road with the passenger side axle engaged. Make sure the fork lines up with the collar when you put the vacuum motor back on.[addsig]
