allabs5150
Last night I went to add oil to my 79CJ 258ci. While the Jeep was running I unscrewed the oil filler cap and a sound of air underpresssure came out of the valve cover.......(sorta like shaking a bottle of soda up and unscrewing the cap)....the engine also started to idel down almost to stalling....any ideas??????????????
Just put a brand new Weber on it a week and a half ago which does away with alot of the factory vacuum lines...could this possibly have anything to do with it????also noticed the valve cover started leaking badly after the carb install....could the Weber be putting alot more pressure back into the crank case?????? ....which might cause gasket failure around the valve cover, or any other areas?????
Any ideas???????Help before this thing makes me nuts
