hi to all,
(JZ 1998 4.0 L6)
I recently was able to fix astalling problem, but to find it i did a lot of stuff that did not help.
One was I took out the CAT converter, and the O2 sensor that was attached to it now i'm wondering if this is causing this problem ideas?
all though my back fireing also happens when the car is cold and i try to rev it. my RPM will reamain at les 1k and i can here small back fire some times in front (on the intake or manifold area) and other on the tail pipe.
I have not goten the codes yet (next step).
also i wont to check the MAP and TPS to begin
Any other Ideas are welcome
thank you ..
			(JZ 1998 4.0 L6)
thank you ..
