1044596
I tried doing a search but I can only get 3/46 viewable for some reason...
Anyhow, When My Jeep hits 100KPH, it starts to vibrate/shake very bad. It doesnt matter if I'm in 3rd , 4th or 5th gear it starts shaking always at the same speed.
I thought it was something to do with wheel alignment or wheel balance or something in the front end, but I've had two mechanic shops say that stuff is fine (not sure what they actually checked) and they say that it's something in the drive line. They suspect it could be U-Joints or that there is play in the drive shaft (which apparantly there is a little).
But I thought if it was the drive shaft that the vibration would be consistent at RPM level, not at speed? Isnt the drive shaft moving faster/slower when going between 3rd, 4th, and 5th?
