Just got finished installing a TJ axle in my '93 YJ and have a lingering question I hope someone will answer. Why is the passenger side or "outside" seal outboard of the vacuum motor housing that's no longer housing anything? Why waste expensive gear lube down the tube when there's nothing to lube? Why not install the "outside" seal at the differential? This is my first jeep & I'm learning as I wrench and ask. Thanks for any answers you can provide.
