Tug-n-pull
87 YJ wippers work at all settings some of the time, hi low and intermittent! ok now most times they only work on hi! some times they shut down on que other times they stop where ever they are when you turn of the switch? Motor seems strong! could it be the turn signal, dimmer, wipper cobo switch is bad or do I need to look else where for the problem? Thanks for any help on this matter! Tug[addsig]
