90Xjay
RE: How to fit a big block into a YJ?
I have had wired for over a year now, a pair of 55-watt driving lights.
I used a 4 prong relay and a Hella switch to wire them.
they have been working fine until about 2 months ago, I lost power to the driving lights, dash clock, radio all at the same time.
After looking around, I found the 10 amp dome light fuse blown!!??
i replaced it and all was well.
Last time I had it out, lost lights again. After remembering which fuse was it last time, I replace it and all was well. ..... I thought.
I checked the driving lights and immediatly blew that same fuse.
The only connection to the two items was that the relay used for the driving lights got battery power from a open prong right beside the dome light fuse.
To test the problem, I moved the battery power lead from the open prong near the dome light fuse to another open prong on the other side of the fuse panel, and you guessed it. It then started blowing a 15 amp power ant. fuse right beside it again.
Can I have a bad relay, that is blowing fuses like this?
Why else could this happen?
Lightless in Texas....90
