Wobbling from new springs
mailtruck
HARD TOP Wrangler
I just installed new 2.5" lift coil springs on the front of my 89 cherokee. While taking it for a test drive today I noticed that occasionally while driving it down the road under normal conditions it would have a nasty wobble in the front end. Is there anything that can be done to fix this without taking the new coils back off? Thanks
are you sure you tightened everything back up? how about alignment?
Chances are somethings worn out. Most likely the control arm bushings and/or the upper end of the front track bar. Make sure you have the proper caster after the lift.
