TerryMason said:What's the problem? Are you having gas spurt out when you finish filling up (many TJs have this problem).
Bounty__Hunter said:There is no valve or stopper at the top, and the pickup screen is at the bottom at the pump.
Your fill tube extends down into the tank further than it does in a 4.0L TJ, limiting your fillup to 15gal. Many 2.5L TJ owners trim that fill tube by reaching in through the pickup hole increasing capacity to 19gal.
No need to modify the pump or sending unit.Will I need to modify the float or the pump in anyway? Do I drop the tank to trim that tube
MattMayTJ said:That's interesting my TJ only holds 10 gallons and it's a 2.5 liter also.
Bounty__Hunter said:No need to modify the pump or sending unit.
Yes, you need to drop the tank to increase the capacity on a TJ, reaching in through the hole for the sending unit.
A '91-'95 YJ can be increased from 15 to 20gal without dropping the tank![]()
