tardis454
Hi Jeepz forum, it's been a while since I've been here.
I've been very busy getting my wife's dune buggy ready for this summer.
I had to clean out the garage to work on the buggy, and I have TJ & YJ parts to get rid of.
I have a lot of 2.5L engine parts left over from a rebuild I did a few years ago.
I was a machinist by trade for 10yrs so I inspected everything to make sure it's up to snuff.
The prices are negotiable, so feel free to make an offer, I need the space!
I'm located in Madison Ohio about 45 minutes East of Cleveland and West of Erie PA.
Here's a list of parts and some photos of what I have for sale.
Two 2.5L short block cores.
The left block is out of a 95 YJ w/120k. It ran with a weeping head gasket.
The right block is out of a 98 TJ w/55k. It had a spun #1 rod bearing.
Good cores, no cracks, cyl bores are stock diameter, main journals are in tolerance.
$150 ea
The 2.5L cylinder head core off of the 95 YJ block.
This is a good core, no cracks, needs refurbished.
$125
The distributor from the 95 YJ engine.
It worked fine, good plug and pick up coil.
$50
The oil pan from the 95 YJ engine.
Solid, very little rust, good oil pan.
$75
Brand new set of .040 over pistons. This is a set of pistons only no rings.
I was gonna build a monster 2.5, but the buggy project came first.
$100 for the set.
2.5L intake manifold from the 95 YJ engine.
This is a complete manifold with injectors.
TPS sensor is cracked, IAC is good.
$75
2.5L exhaust manifold off the 95 YJ engine.
Good manifold, no cracks good studs.
$50
Two 2.5L crankshafts.
The top one is from the 95 YJ engine.
The bottom one is from the 98 TJ engine.
Both are stock diameter on the rods and mains.
The TJ crank (bottom) had a spun #1 rod bearing.
I mic'd it, and there's plenty of material left for regrinding.
$50 each
2.5L pistons and rebuildable connecting rods.
1 set is from the 95 YJ engine, 1 from the 98 TJ engine.
The YJ pistons are shot, the TJ pistons appear to be ok but should be replaced.
$50 a set
Misc engine pulleys and idler pulleys..
$10-$25 each
AX5 5spd inspection cover.
From the 95 YJ transmission.
$25
87-95 YJ copper & brass heater core.
OEM style, brand new in the box, never used.
$35
$150 ea
$125
$50
$75
$100 for the set.
$75
$50
$50 each
$50 a set
$10-$25 each
$25
$35
