jay79cj7
Apparently there is a common problem with 97+ XJs having the power window controllers on the passenger doors stop working. I thought it was just lucky me and had been dealing with it for a while because it wasn't worth trying to track down the problem. No big deal, just annoying that your passengers have to ask you to roll down the windows, as if the window lock was on.
When looking for something else the other day I ran across a thread on another forum and apparently this is common and easily fixed. All that is likely wrong is a bad window lock and you can splice two wires in the door harness together to bypass the switch. The service manual says that the module is not serviceable, but that is not exactly true. I actually went to Radio Shack and found a switch that would fit (with some persuasion) and replaced the broken one. The module comes apart if you remove a couple screws, pop a couple snaps, and pop off the buttons on the top. Not as bad as it sounds. Taking the door trim off to get to the harness/module was pretty easy too.
I just thought it might be worth a mention to anybody else out there that this has been annoying!
http://www.naxja.org/forum/showthread.php?t=93806
