YellowTop or RedTop ....
firestarter
Hello all,
So my battery is at its end and I'm looking at the OPTIMA line. Anyone have experience with these? At the moment I don't have any crazy accessories on the rig but plan to be adding a few (winch, light-bar, etc ...). I'm thinking of going with the Deep cycle YellowTop D34 ......
please advise :-)
Thanks in advance,
Go with the yellow top if you plan on doing much winching, it can handle the frequent discharge a lot better than the redtop.
I went with the Bluetop Optima, the D34M, same combo deepcycle/starting battery as the yellow top but it adds stainless threaded lugs to the top of the battery, makes attaching the winch cables much easier.
Thanks for the input. So maybe i'm confused on the stats for each of these classes.
All the battery's seem to have about the same c/20 capacity rating so i would think they would all have the same discharge behavior but from reading the literature and ignoring the numbers the yellowTop claims to be able to recover from a discharge more easily. I don't really see (in the numbers) where the yellowTop stands out? Is it just a radically different design that's more efficient over long periods of time?
It also seems like if the batter is lets say 80% starter 20% heavy use (winch) that it might be more favorable to go with a redTop? thoughts?
The redtop is not a deepcycle, so it won't recover very many times from a near full discharge. A deepcycle is rated to recover 200+ times from a near complete discharge with little to no damage to the battery.
If you don't think you will do much winching, get the redtop and save a few bucks. If you want reliability in all situations, go for the yellow or blue.
Red, I would only add a yellow if you have a red as a primary battery. the yellow top is not designed to start an engine under load, one hard start and the battery is pretty much done. The red top compared to a comprabile yellow top (34/78 red top vs D34/78 yellow top) actually puts out more CCA, 800 compared to 750 and under 32 degrees it's 1000CCA compared to a yellow top 870. they both have similar capacity and internal resistance.
If you want the best of both worlds, you will need to pony up for a Blue top, often called a marine grade battery, it is a deep cycle starting battery. it will have the same benefits of a deep cycle with quick recovery long low amp loads, but can provide the CCA for hard starting
I really don't think you can kill a YellowTop from starting a Jeep. From Optima:
34 RedTop: Description: High power, sealed lead acid, engine starting battery
D34 YellowTop: Description: High power, dual purpose engine start and deep cycle, sealed lead acid battery
D34M BlueTop: Description: High power, dual purpose engine start and deep cycle, sealed lead acid battery
Johnny:
I think there is some confusion here with Bounty. Correct me if I'm wrong, but I think by "under load" you're referring to going up-hill, in-gear. Not just "starting the engine" I've had to do it a few times in nasty situations where I didn't have enough feet and couldn't roll back cause of the pucker factor.
yes, under load. I got almost 8 years out of a red top, put in a yellow top as an upgrade, was in the jeep no less than 3 months, one start under load and the battery would not hold a charge, apparently a cell went bad. got an exchange becuase it was prorated, second yellow top, put a trickle charger on it for a winter, killed the battery again (unknown to me, you not supposed to put a trickle charge on sealed battery's) went back to a red top that someone gave me, I've started it under load number of times, no problems what so ever.
