PatrickPresti
Hi Everyone,
Need some help with an oil leak. I had oil dripping off of the inspection plate for the transmission. After removing the inspection plate, I saw oil all over the inside of the bell housing.
After I removed the transmission, I was questioning myself if the oil was coming from the transmission. I observed no oil on the pressure plate/clutch at all. I removed the flywheel and there was no oil leaking from the rear main seal.
However, I noticed clean oil on the oil pan gasket where the oil pan curves around the main bearing housing.
My question is, if there was an oil leak at the oil pan gasket by the rear main bearing housing, could that oil travel down the inspection plate and then sling all over the inside the bell housing?
Also the oil pan gasket in brand new...
