YJ steering column swap
Jblasz
Picked up a tilt XJ steering column from the junkyard for My 89 YJ manual trans. From everything I researched and read. It should bolt right in with a few modifications. But after I got bolted in. It ended up being about 3.5 - 4” to short from connecting to the intermediate steering shaft behind the firewall.
Will the stock shaft pull out that far ? Or do I have to try and find a longer shaft. Or do they make an extension? I haven’t seen this problem in all the searches I’ve done. Everyone just says the columns are the same length with their not
