Latest activity
  • superj
    superj replied to the thread Fuel Gauge issue.
    So its a single connwction sensor? If so. The pull the sensor and check it. It acts like its bad since it pegging to foll deflection
  • Engir
    Engir replied to the thread Fuel Gauge issue.
    There is only one fitting and it is only fits one way but I can check it next time I am at the garage and see if the mechanic working on...
  • Engir
    there is only one fitting and it is only fits one way but I can check it next time I am at the garage and see if the mechanic working on...
  • superj
    superj replied to the thread got another tj.
    The new parts jeep started today. The new fuel pump came in so we dropped it in and the jeep fired right up
  • superj
    Yeah, something grounded since the gauge is reading pegged to full
  • M
    mark sr replied to the thread Fuel Gauge issue.
    wired up backwards ??
  • Engir
    The fuel gauge on my 1987 Jeep XJ was not working when I purchased my XJ. I did an electrical test with my multimeter according to a...
  • TerryMason
    TerryMason replied to the thread Ford gpw 1942.
    That looks like a blast. I'd have been nervous when the front end came up while climbing the hill (at 1:09)!
  • superj
    updates: i crawled under the 1k tj in search of the crank sensor and got it changed out with my youngest son. while under there i...
  • A
    aamir567 replied to the thread Ford gpw 1942.
  • superj
    superj replied to the thread NEW 32RH Transmission dipstick.
    32rh dipstick measurements 28-7/8" from what would be the top of the tube. Bottom of dipstick to minimum 1-1/4 inch Bottom of dipstick...
  • superj
    this parts jeep was missing hte transmission dipstick and the one from the 42rle in the 03 wrangler is to long. i have been googling a...
  • superj
    Well, further cleaning and messing around ahows some small holes under the carpet by the foot areas. And the jeeo starts on fuel being...
  • JPNinPA
    JPNinPA replied to the thread Cherokee won’t start wet.
    So as you turn the key there is no click? Does the engine turn or no? Never look down on anyone unless you are helping them up -...
  • T
    Tomcuse replied to the thread Cherokee won’t start wet.
    Power to everything out no click
