chunkysoop said:I've never messed with the rear sway bar, but I've always just removed the front one completely on every jeep I've owned. Does disconnecting the rear give much extra flex? I've heard it said yes and no...
	superj said:most people don;t realize they have or don;t have a rear sway bar and don;t know the effects of them. and this is not only a 4x4 jeep forum , there are 2x4 models and those can be very quick fun vehicles so i think this could be used to help both versions.
i prefer to have the largest front and the stock rear sway bars because we have no 4 wheeling here, except sand.
well, this too, i did this today
this is rock crawling here.
bugleboy said:lol we are just trying to explain whats most safe on and offroad
If you want to be safe, buy a Volvo, if you want streetability and 4 wheeling that's just sand or dirt roads, get a Toyota, for serious off-roading flexing crawling climbing being amazed by what you can do, a Jeep that's moderately built up is the only way to go, and to get the most out of non-flat land 4 wheeling, sway-bars are more than useless, they are a hinderance and will get you in a position where they will not let your wheels touch ground, when your at 50 degrees on rocks, the sway bar can prevent the wheel you need most from touching ground. So it really comes down to what kind of off-roader are you, mud, sand, dirt roads, then yes, if you want your Jeep to handle like moms station wagon leave all stock equipment where it is and spend your money on stereo equipment, if you want to do rough rocky mountainous crawling, climbing, off-camber technical or extreme 4 wheeling then accept that you have a Jeep, not a car and the "handling characteristics" are going to be very different, if they aren't, why own a Jeep?
And if all you have is sand and mud you wouldn't be asking about your rear sway bar, and if all you do is street driving in a Jeep convertible you wouldn't be asking about removing sway bars either, and if that's all you then this isn't a thread you should worry about as its a non-issue for the mud, sand, street non-rock guys. ...
southtj said:but I don't want anyone thinking there will be no difference if removed or that it is recommended.
I haven't run a rear sway bar in 2 years, I trailer, tow and drive to trails, I have driven over 1000 miles in the Jeep to a trail, no rear sway bar and felt no different, so like I said, depending on your style of wheeling, your style of driving, and I guess your uncommon sense, you don't need or want a rear sway bar.
