PoliceMonkey161
Hello All....... So, I'm re-building my Dana 30differential. And just like the AMC 20 I did last month, I'm using POR-15 rusttreatment as a primer on most everything that is not in direct movement or is apress-on  fitting socket. This stuff is awesome!
But I found a trick (or maybe I'm the last to catch on) to preppingyou parts. For small parts like the steering knuckles, hub, caliper anchorplate, hardware, etc. after wire wheeling them, put them in the dish washer.Sounds crazy, but it moves oil and grease leaving a little rust patina which isdesired with POR-15. If it will fit in the dish washer, put it in there. But bewarned, it will leave a little dirty residue inside the washer.
