dennisonwj
1988 Jeep Wrangler YJ Laredo, 4.2L, manual transmission
I am switching out my brake booster with a new one. I am disconnecting the booster push rod to brake pedal connection under the dash. I am using a Haynes manual and they make a statement about how the assembly should be connected that is contrary to what I see under my dash, and I want to make sure I have it right.
The following perspective is from you siting in the front seat looking out the windshield. At the moment I have a bolt passing from right to left though the assembly. From right to left, it goes bolt head, some bushings, brake activation sensor, bushings, booster push rod, brake pedal arm, 2 lock nuts.
The Hanynes manual kinda infers that the booster push rod should be connected to the left of the brake pedal arm. I do not know if they are referring to automatic transmission jeeps or ALL jeeps. Could someone please verify if my setup above is right to the Haynes manual?
- Thanks
- Thanks
