The proper way to bleed the cooling system on your Jeep is to loosen the Allen screw on top of the intake, right where the upper radiator hose attaches to the inlet.. Use a radiator funnel that attaches like a radiator cap. Fill half way and see if it pushes some air out of the bleeder, close off the bleeder enough that it stops leaking coolant. Start the engine and let idle. Set the HVAC to full heat and monitor the temperature. Slowly loosen the bleeder screw until you see it bubble or leak coolant out them close it off again when you see it spewing out a solid stream of coolant fluid, no air. Check the funnel and make sure it maintains half full of coolant. Be aware that the coolant can reach  around 212 degrees Fahrenheit. The thermostat should open around 195-198 degrees most of the time before the boiling point of 212. When this happens , the coolant level on the funnel will go down as it fills the cooling system in the engine. At this point you will need to burp the cooling system again through the bleeder valve. Remember not to remove the screw all the way, only loosen it enough to expel the air from the system then close it off again. Do this at least 2 times when the thermostat opens and closes. After you have verified there's no longer any air in the cooling system, with the engine still running, remove the funnel carefully without burning yourself with the hot fluid , install the radiator cap then shut off the engine. If you turn the engine off before you install the cap back on, the boiling coolant will spew out of the radiator and possibly burn you. Wear safety goggles, gloves and protective clothing......  If the heater core is plugged , the temperature or the inlet and outlet heater hoses will differ quite a bit. You can also test this by disconnecting both hoses and use a garden hose to shoot water into the heater core and see if there's any restrictions.  Sent from my iPad using Jeepz
