ElSapoRojo
So bringing life to a dead post here. Im having a 70mA draw on my battery. This is after i have pulled #7 fuse. Is this to much of a draw? Needing to figure out if the drain from #7 is my only problem or not.
Thanks for the reply. Yes. 96 jeep GC limited. When ive tested it doors are closed but alarm off. Hood light unplugged. I know what the BCM is thats why ive pulled that fuse. Unless there is a second fuse? Is the BCM a dual system possibly?
All lights function. Alarm works. Only thing strange is i can set the alarm when the driverside door is open. And sometimes the lights dont come on when the driverside door is open. With any other doors or hatch open alarm wont set and lights work as they should. i will try what you suggested this weekend. When i have daylight to work by. Thanks again
Hi to all
I have a 98 grand Cherokee 4x4 4.0L 6cyl.
My battery is being drained tothe point were it will not stay charged even if a disconect de terminals.
this is what i´ve done
I disconected the PCM, took out all the fuse that are in passenger side, disconected the module that is under the hand bracke, the starter also disconected,. and with a current tester I still found some current flow. SO i went to the fuse box that is next to the battery (while all of the above were disconected and no fuses)and when i took out the MUX/T TOW fuse current went to zero.
so my question is what does this fuse power?
becasue this is the second battery in 3 weeks i dont want to buy another untill i fix this
please help
thank you
Hi to all
please help
thank you
Hello everyone.i read all the posts,i am from greece i have in my shop a jeep grand Cherokee 98 v8 with the same symptoms of battery drain..fuse 7 and cb2 have all the current...i read for the switches, i removed all and the locks and rear lights and everything i believe and i can't stop it, i am very confused..my question is what exactly needs the bcm, ddm, pdm to sleep?the car haven't a alarm and the locks have only 2 wire no switches.another thing is that haven't the code for the radio but i believe that isn't a problem,iam right?thanks a lot any ideas are welcome
It sounds like you really know your way around the alarm system and BCM wiring thanks for breaking it down so clearly. Your step-by-step method of checking each switch with an ohm meter and isolating the circuit at the BCM harness makes the process much easier for anyone trying to track a battery-drain issue.OK, if you answer my specific questions that will be a start. They are:
Are you able to set the alarm at all, either by key or by hitting the door lock switch on the door?
Does the light flash on top of the dash indicating it is alarmed?
With the alarm set, when you enter the drivers or passenger door, do the interior lights come right on when you turn the key in the lock?
If any of the alarm or interior light functions are not working exactly as they should, you are likely on the right path and the problem will lie either in the drivers or front passenger door lock switch on the back of the lock cylinder, or the rear hatch detector, rear window detector switch, or the 4 door open switches. (My case it was the drivers door lock cylinder switch, broken in the unlock position, making the BCM think someone was trying to legitimately enter the vehicle with a key. You can pay $40 for these or scarf them at a bone yard for almost free.
Check them with an ohm meter to make sure they work when you turn them, and don't get the left and right sides mixed up.)
If the alarm or lights aren't working as they should, what you can do is back up and read the BCM wiring diagrams and posts in this thread, there is a wiring diagram showing where each of the lock switch wires come in, lock switches, hatch, rear glass, and door switch wires. Then, at the BCM harness, (it's the smaller connector that you can unplug without taking out the BCM,) one by one, using the diagram, cut and reconnect the little copper wires for the circuits you suspect and see what effect that has on the current draw. In this way you can isolate the problem. Is what I did. When you disconnect the right one the bcm will time out after about 40 seconds and you will see the current drop to very little, about ~10ma.
