The answer to the 47 vs 49. +/-2 is to replace the pump and fuel filter.
Did you find burnt valves?
No. 2 were worn and 1 was close to worn so he changed all 3. The rest were fine. None burnt. Any other signs of running lean?
			Being you took the head off ... Be sure the misfires are not from a leak around the head, intake, plugs, injectors... Bad plug.   They are easy and cheaper than dropping the tank.
As far as the misfire codes, they're all the same as before, with the exception of 1 less (
PO302 Cylinder 2 Misfire Detected):
PO300 Random/Multiple Cylinder Misfire Detected
PO304 Cylinder 4 Misfire Detected
PO305 Cylinder 5 Misfire Detected
PO306 Cylinder 6 Misfire Detected
Honestly, I'd have to rule out an intake gasket leak and plugs. If you mean the intake gasket, it was torqued to spec and to get the exact same errors in the same cylinders would be a heck of a coincidence. If you mean hoses and connections to the intake I'll double check them. Same goes with the plugs, unless it was just one. When I reinstalled them they were not in the same same order, yet again I have the same 3 remaining errors in the same cylinders. If they were the wrong plugs altogether I'd replace them all. They looked great when I re-gapped and reinstalled btw. Nice and clean.
Along with a compression test today, I also plan to swap 2 injectors tomorrow to see if one of the errors follows the injector to a new spot. While I'm at it I'll install new O-rings.
Any chance it could be the coil or distributor? If so, can these be tested?
EDIT:
Latest compression results:
Cyl#
1 ------160psi
2 ------160
3 ------165
4 ------165
5 ------163
6 ------160
Overall the compression has improved since the original test. Cyl.#3 was the only one that decreased from 175 to 165.
Again the engine was warm and all the plugs were pulled. The coil was disconnected as well as the FP fuse. I let it crank about 5 times.
For the heck of it I swapped plug wires 3 and 4 to see if the problem follows.
Today, when I hit about 52 miles, since the last code reset, the CEL came on. I was go down a slight incline at the time on the freeway, 3000rpm @75mph. I also happened to be recording it at the time. See 00:39.
www.youtube.com/watch?v=nXL0MvfUIS8
When I got home I read the codes. All the same plus a bonus PO 441 code = EVAP... Purge Flow Fault. I checked my gas cap and hoses at the purge solinoid and they seem fine. I'll let this one ride for a while and recheck the codes after the next reset.
The only things I've done different since the last reset is clean up some grounding straps and ran the above compression test, during which I smelt gas which may have to do with the 441 code.
