I'm stuck!
I bought a 1992 Jeep YJ for my son and I to rehab for his 16th birthday
Wen we bought it the speed sensor was broken off. We bought a new speed sensor, installed it and now the jeep sputters and want to die and idles rough.
When we disconnect the speed sensor it runs great. It is an electronic speedometer, not cable. I have three wires. One reads 0 volts, one reads 5 volts and one reads 9 volts. I connected the wires according to the diagram that came with the speed sensor and wiring harness.
when I switch what i believe is the power supply wire and the wire to the speedometer the jeep will not start at all.
could the fix be as simple as replacing the speedometer?
The jeep has had a brand new engine, new starter, new fuel filter, all lights, wipers, dimmer, switches, gauges and even the tachometer are all working.
any help would be greatly appreciated!
