15" Wheels on a '09 jk
bigbyrdjk
Need help .I know that there are threads on this but I can not find them . I want to run 15 x 8 . What back spacing do 8 need or do I need to run spacers. Thank you for your help in advance.
In not even sure the 15 's will fit over the brakes and tie rod ends. JK's run 16 and 17 inch wheels with a 5 by 5 bolt pattern. If your trying to put TJ wheels on it. The have a 5 by 4.5 pattern But im not sure it will work. Good luck to you. I hope im wrong and it does
Per JpMag...they did mention some but not all, 15" wheels could fit a jk. Also I saw a used jk on a dealer lot last fall with 15" wheels from an older wrangler but he was running adapters/spacers to pull it off.
