I have new 2in lift shackles I'm thinking of putting on my jeep cj7 I have a 4in spring lift on already will I have to changs any thing. Like the drop trans. I have 2in drop now on the trans.
2in lift shackles will net you about 1 inch of lift, so chances are you won't have to change anything, but you won't really know until you put them on. You may need stuff like longer brake lines.
I'm not a fan of longer lift shackles. I'd put a 1 inch body lift on there for about the same effect.
Making the shackles longer can and will affect the angle of your pinion; just something to keep in mind, as it COULD cause vibrations in the drive train. I am also not a fan of lift by shackles, as it puts unnecessary stress in the shackle mounts.
