That's the setup I had on my YJ. It's no different than running a 33x12.50x15 on a 15x8 which is a common setup. It will help hold a bead when aired down offroad too! Keep an eye on air pressure, and rotate them and you should be good to go.
With the stock backspacing they'll rub. You can either get wheel spacers, different wheels, adjust the steering stops, or just live with it as many do.
