Doesn't make it right, or smart. Could be 1000hp and 52" tires, either way it's a ticking time bomb. Using minuscule axles with high horsepower and the leverage of large tires is a recipe for disaster and it's not a good idea to recommend it just because somebody has limped it along or been lucky.I disagree there a guy on here that has a 383 pushin 500horse with the 30 up front and amc20 rear runnin 38 for ten years and put over 16000 offroad miles on it
Thanks for all the insight guys, I wish that I could go with the 60's but they are out of my price range for now. So the 44's it is, for use as a daily driver what gear ratio do you think that i should go with, I want it to be good for a daily driver but still do what I need it to off road. Also I'm looking to do a Full Traction Suspension 6" Long Arm Suspension System with M-Force Monotube Gas Shocks, thoughts or better suggestions?
I recently dropped in a 350 Small Block in my 04 TJ, I need to get new axles put in. I was looking at the G2 Danna 44's, suggestions on axels and lockers?! Also what gear ratio do you think I should run with 35s?
